Antenna Separation
Peter Walker
Feb 23, 2011
119
60
I am thinking about mounting 2 vertical antenna's on the same mounting pole and was wondering what the minimum separation distance should be between the the two main elements? Center to center if I mount them the way I have in mind, there would be about one foot between them. Is that enough? Would they interfere with each other? Suggestions? Advice?
