Are there any sources for these? I know, odd question, but when my garage door and my 102" met last night, the door pulled that ball off, now I cannot tie it down for low clearance places (my garage!)..
Although somewhat expensive IMO, you can buy one of these. These are nothing more than whip couplers with the stud rounded off. If you have any of those couplers salvaged from other antennas, you can also make your own.
https://www.ebay.com/itm/Corona-Ball-for-102-Whip-Steel-whip-CB-Radio-CB-Radio-Antenna/202653083712
I would just replace the antenna. Replacement ball will not hold up and form a corrosion between the antenna ball.Are there any sources for these? I know, odd question, but when my garage door and my 102" met last night, the door pulled that ball off, now I cannot tie it down for low clearance places (my garage!)..
You can find them much cheaper. $20~$25 for a 102" SS Whip, the HD Hustler spring can be found for around $37. Don't buy those cheaper ones they corrode around the braid and break.I had to ask the seller what size those balls are, they're 5/8" OD.....
Man, I'd really hate to have to buy another antenna, $45+ a piece plus shipping...
Where do you folks find them for so cheap? Everywhere I look, they're $40-$45+ and then add shipping... If I found them for $20, I'd probably buy 2 to make the shipping worth it. The last one I bought on Amazon came in a PVC tube with caps on the end, so 2 would fit in it easily.
1). Antenna Parts Outlet. Will custom drill.
2). See also www.k0bg.com on “Controlling Static”
3). Nicest was the 102” piece from now defunct GUNNY PUCKS
A leisurely search one afternoon waiting to unload revealed the ultimate: perform a blinding shine and clear-coat to a fully-copper toilet bowl float. Talkin’ shit the will never be the same again.
Actually, go to www.boilersupplies.com
Copper round floats starting at 3.5” diameter.
This could work also:![]()
