Causing interference with neighbours"Rotel Tuner Amp&qu
  • Thread starter Thread starter Frillyneck
  • Start date Start date
F
Frillyneck
Guest
Hi , can someone please give me some advice as to what to do to stop me coming through my neighbours Tuner/Amp.He is the only one who is getting it.It is a Rotel Tuner Amp.My grounding is excellent,I have also checked his grounding which is very good as well.My Swr is 1:2:1.I have tried the ferrite rods and clamps but they dont seem to be making any difference.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":(">
</p>
</p>
Re: Causing interference with neighbours"Rotel Tuner Am
How much power are you running? Also what is your antenna configuration?
The RFI is probably coming into his stereo equipment through the electrical house wiring. Go buy him a power strip that has RFI attenuation. You can find them from radio shack, compusa, anywhere that have 45+ dB RF attenuation. There's a number of other things you can do also. I suggest picking up the ARRL RFI book. It has all kinds of info on how to track down and eliminate the interference.
</p>
</p>
