A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
Cherokee AH-100 FM Receive plus 5k shift modifacation
-Solder SJ2 Jumper pads located just left of the channel modification jumper. To change shift press CRSE button.
Cherokee AH-100 OPEN CLARIFIER MODIFCATION
Locate jumper J94 located just left of C178 on main PC board. Locate jumper J132 cut J132, add insulated jumper between J94 and J132 (put jumper on J132 on half closest to the front of the radio).
Cherokee AH-100 Tweaks and Adjustments
-RV1 RF Power Meter adjust RV2 Squelch Level adjust RV4 AM Carrier adjust RV7 Modulation Meter adjust RV11 13.8 Volt RV12 S-Meter Adjust Both AM and SSB. RV14 SSB ALC adjustment. RV50 Clarifer Center adjust
yes I have the info, however there is no makings on the pc board components to correspond with the mod. I need a photo of where it is showing the jump points. Thanks for your help!!
