Cobra 140gtl with two dead channels?
Radio Face
35
3
38
56
Just out in the shed today playing around with my Cobra 140gtl that is hooked up to my base antenna.
Anyway, noticed it will not give a static sound on channel 39 or 40. Also no transmit or receive. When I key it up on 39 the transmit light flickers and it makes a quite sputtering sound but on 40 nothing at all through my talk back radio. When I switch to another radio and try and transmit back to it, the signal meter moves but no sound. Any ideas? Thanks Radio Face.
I would tweak the vco first check the voltage but sounds like the vco drifted a bit and maybe an adjustment will cure the problem.
Does the radio have extra channels?
Reactions: 357magnum
