So I was restoring this 2000 back to stock in the audio by replacing TR24 so I can adjust the AM modulation.
After putting it back I still could not adjust the modulation and then I Noticed that R131 was also missing and and R124 and 126 were changed to 4.7k. So I replaced 131 with a new 10k but left 124 and 126 as is. But when I tested it, the audio was like “machine gun” sounding. All chopped up, kind of hard to describe. The only way I could stop it was to pull R131 out again.
any thoughts on why that would cause that issue when restoring those parts? Should I change 124 and 126 back to stock? Maybe that’s it?
also the SSB ALC pot doesn’t seem to do anything either. Is that disabled the same way the AMC is by removing TR24 etc or if not why else would that not seem to work?
thanks.
thanks.
