BIONIC_TEXAN88 said:
thanks bushwacker, that helped a bunch. I took it to my tech and he realigned it for even power across the band. Like you said, my swing did drop but I am even now, only getting 27w pep now.
think I outta try the cap resistor mod with it to get my dk down for an amp??
Yea you can try it out... its up to you. What that cap resistor mod is doing is lowering the voltage to the driver but letting all the audio through. The resistor part drops the voltage which lower the carrier.. the cap is there so the modulation can still make it into the driver... in a cobra 29 style radio and most am radios, all the modulation comes in with the voltage to the driver and final... in a linear rf amp you have the modulation going into the base of the transistor (input) and just voltage on the collector (output) but with a cobra 29 the modulation and voltage is mixed... so if you want to lower the carrier you will have to drop the supply voltage but this will also drop the modulation... but if you add in a resistor to drop the voltage AND add in a cap it will let the modulation flow through... this is the job of the cap...all this keeps all the swing (with the cap) but lower the carrier ( with the resistor).
This little swing kit gimik is put in a convient jumper... if you want to see what part of the rf amp this swing kit effects all you have to do is follow the jumper... the jumper runs from the 12 volts modulation/voltage supply line to the driver.... right beside that jumper is an rf choke that runns off that 12 volt/modulation supply line... this is what supplies the voltage and modulation to the final.. the choke is there to prevent any rf from getting back into the audio amp.
So... all the work you did changing the final to a fet is in final rf amp .... by putting in a resistor cap you are not messing with anything running directly to the final since choke L15 is what supplies the voltage/modulation to that part of the circuit. Putting the resistor cap in the usual place will do its normal job of adjusting the voltage and modulation to the driver. There should be no worry about it affecting any of your work on the final directly.... but you are changing the drive to the final by driving it with a lower carrier.
What I'm saying is you can put a swing kit in without it messing up the fet.... but I'm not sure how the fet will respond to a much lower drive level and if it will work how you want it too.
Since you did alot of work on the final section , I'm not 100% sure the swing kit will work the way you want it to.
Basically what I'm rambling on about (lol) is for you to go ahead and try it out. The swing kit modification controls the voltage and modulation to the driver and therefore the drive level into the final. The big worry is if it will mess up all your work you did in the final rf section......the only thing this mod does to the final rf amp is change the drive level into it/..... and if the rf amp does like it.... take the swing kit out..... no harm... its very similar to changing the drive level into an amp.
I say try it if you want.... but I would not drop a huge amount of voltage at the start. In other words don't use a large value resistor to start....
Hopefully that gives you an idea of whats going on. You know what your doing when it comes to doing this mod, so the decisions yours.If you don't like the rersult just remove the swing kit
Take care and no thanks needed..... you know what your doing.
HootyAL also said the same thing I did... I just said it the LOOONNNNGGG way LOL. So it wasn't just me alone.
Take care and sorry about the long winded rambling... sometimes I just go on and on.
