I have a cobra 89xlr i am trying to mod... i need to push it into the 28.200 -28.300 mhz range
Recieve does not matter... this will only be transmitting... recieve does not matter... i also dont care about being able to switch between cb and 10m HAM band
Things i have tried
Replacing the the 10.240mhz crystal with something higher... this was unpredictable
Tried replacing the 10.635mhz crystal with 11.325
No dice
Connected pin 21 and pin 19 on the 858 pll
This got me into the 27.765 mhz or so range... mot quite there...
In all cases the vco seems to loose lock at around 27.675. Retuning L20 seems to help this
Things i have tried
No dice
