Connex 3400 program module
Kung Fu Panda
Jul 5, 2018
43
9
18
52
Does anyone have a program module for sale. Connex 3400hp. Someone also mentioned a mod to not use the module. Any help thanks.
You can take a DVM and measure the header pins resistance.
Check by tracing the wires back to the header, - and start at one pin, measure using 1X scale on the DVM using that pin to start, and simply measure for "short" (low resistance) to another pin, then once you have the pins used, the process is pretty easy to make permanent.
I believe there is only one "jumper" embedded in the harness Dongle.
Reactions: sp5it
