  • Retevis is giving away ANOTHER RA89R Radio for Independence Day! Click Here for more info!
CONVERSION SKELTON 150 to ssb
doctor
Supporting Member
I Support WorldwideDX.com!
Aug 1, 2006
1,036
80
58
83
indiana
Anyone know or can this skeleton 150 am amp be converted to operate on ssb easily or not?
thanks
doctor :(
Howdy Doc , look inside the box , It's made by Texas Star , it might have 2 x 2290s in it , I had one that did, Jeff might be right as well , let us know. But one thing is for sure , it is Class C AM for the most part ,it might work on SSB (have you tried it there ?) even though it is class C , it can still work but it isn't the best of situations concerning audio on SSB in Class C , but it still could work. But the amp would work very well on the AM side of your PC 122 , that much I do know. :) If your looking for a SSB compatable small amp in the future new or used , I might be able to come up with something for you if need be.
amp
Ill check it out, yep if you come up with something let me know, trade plus some bucks ok with me..to tell you the truth I detest am to many bozo's on, that why I stick with ssb.
doctor :shock:
Did you ever end up doing anything with this amp?
Like adding in the delay?
Its a class c amp so I'm not sure if you would want to use something like that on ssb since you are a serious ssb'er. You might end up adding in a delay and a bias circuit to get that amp sounding a little better.
Just curious if you did anything with this amp yet, what you did with it, and how its sounding.
Take care
amp
Actually I never did anything with it, I in fact picked it up today from a friend, and he has used it on ssb, said it worked fine, it probably isn't the best sounding, but it is shall we say a standby amp anyhow.
Thanks for asking
doctor
    boog351 has left the room.
