Courier Bl-100
bigred222
Key Up City Radio
Aug 28, 2006
1,155
53
58
36
Stamford, CT
www.cbjunk.com
I have a courier bl-100 And right now its a strickly sideband only amp. It swings like 80-120 Watts on sideband. Ive been told that the plate voltage has been jacked pretty subtantially up to about 800-900 volts. Are there any tubes that would fit in the same socket and be able to run on the same power supply in the amp that could do any more power???
Doesn't make any real difference between tubes (even if there is a substitute). If the power supply won't handle it, there will be no more power output unless you break one of the laws of physics somewhere along the line.
