Howdy Friends. New here as I just picked up my radio today. Got a killer deal on it as I knew it was going to need repair. I am decent enough to replace some caps and have quite a bit of soldering/small electronics repair under my belt but this is the first time I have tried to repair something pretty old.
I have not powered up the radio yet as I wanted to at the very least look through it first and clean a bit before going nuts and applying power to a radio that has been sitting for decades.
I heard some rattling around and found these bits in the radio.
Searching around the radio I found these missing/damaged pots? If I can find the original value is it possible to just replace them with new standard pots provided the values are the same?
For reference here they are in relation to the rest of the board and here is a pic of my radio. If anyone knows the values or has had to come up with a solution for a similar issue any advice is appreciated.
I can see that there are 3 of them. The one in the middle (the intact one) looks like it says 30k. The one I found rattling around says 50K and there is one missing ring. The arrow things all seem to be there...one was rattling around one is stuck there in the pot and the other pot...as I said is fully intact.
My guess is someone was messing with these and broke one. That may have been what landed it on a shelf years ago.
