hello,
I was thinking about replacing my Cushcraft 13B2 for a Cubex Scorpion II. I can find no user manual online nor will Cubex return any of my calls.
Anyhow, I will be using my existing Belden 9913F. Can anyone tell me if it will take a direct connection with the 9913 or will I need to use a short jumper to connect the driven section. Seems like I read somewhere that the heavier cable puts stress on the wire causing problems. I ask cause I've never seen one up close.
Also, does the Scorpion utilize a UHF connector or a direct feed?
Thanks,
Mark~AC8EO
Thanks,
Mark~AC8EO
