d104 wireing problems
Apr 30, 2009
5
68
i am trying to wire a d104 to an cobra 142 gtl, with no luck. i have been told that the wires go on 1. white, 2. shield, 3. black, 4. blue, 5. red, and 6. yellow n/c. is this right??? it recieves, but no transmit.
the mic has a black base, then crome, and the head is black. also on the bottom is swicthes for ets, pad and vox......what are these??? it takes a 9 volt battery also. thank you
Your wiring appears to be correct. The ETS switch turns on/off the roger beep. The Pad switch is a 20dB audio attenuation. The VOX switch is used for VOX (hands free) operation. I have seen the black/chrome models commonly referred to as a "D104 Special" but don't know if that's the official name or not.
When you say it doesn't transmit do you mean it keys the radio but no audio output, or that it doesn't key the radio?
