Diode/Resistor mod for AT Ares2/QT40
MKwrench
Wooohoooo!!!
Aug 6, 2023
158
151
53
55
I've always called these the "Red Devil NPC" mod, but I guess it's more of an "auto expanded envalope" or PPE.
I only use these mods to recover output linearity form an amplifier, which can suffer at the original 4 to 1 input PEP to carrier ratio. Sometimes 6, 8, or 10 to 1 might be needed depending on the amplifiers sensitivity to carrier power and desired output ratio.
I have a Qt40 that I've used as a bench radio for a long time and would like to put it in my truck for winter because it's way more stable at lower temperatures than any of my older radios. I have a little RM-Giggity KL203 that I use in the truck, but found that "*decently adjusted*" output is about equal with or without the amplifier because of the lack of the mod.
The board is simular to the AT5555, but the usual "Red Devil" doesn't work here, and I hear that the menu NPC only disables limiters causing nastyness. I havn't really fiddled around with this radio enough to figure anything out (or break something...lol) yet.
How about you guys?
I wonder if anyone has put together a clean/easy NPC or swing mod for these yet?
