Does "Ranger" make the SRA-198 noise canceling mic?
Mudfoot
Elmer
I Support WorldwideDX.com!
Jun 17, 2009
11,280
6,681
698
64
Southeast Ohio
If so, does it has the same wiring as the SRA-158 stock mic?
Wasn't sure if it was a nasty clone or something.
everything i have seen appears to be ranger made.
the 198 is a 4 pin mic however weren't the 158's made in both 4 and 5 pin...
just depends what you have.
Reason I dug up this post is that I'm looking at the SRA-198 and this thread came up in the search. I've been wanting the Ranger SRA-198 and I'm wanting to use it on my Galaxy 959,Royce 1-604,Radio Shack TRC-443,Uniden505. All will work with the Galaxy Pinout except the Royce where the Audio and Shield wires are reversed. The TRC-443 has better response with my stock 959 hand mic. As far as the Royce goes,I can make an adapter to use Galaxy style plugs on it. All being said,I wish the 198 was amplified.
Side note:the 443 squeals with the 2018 Xtreme keyed down????
I'm still impressed over the amount of modulation that the TRC-443 has in reserve. Wow!
A mic cord extension will do nicely
well
if you never dealt with redman. he is a very rude person.
if you have a problem. he will tell you you broke it. just read his feedback on ebay.
best of luck
best of luck
I know he sells stuff in Amazon but I didn't know he was a Ebay Seller. :ohmy:
And yes,I have bought stuff from him.
What his Ebay name?
Found him.
Okay,he moved to Port Charlotte,Fla. recently
