Eagle Mark III
fm969
Feb 16, 2010
10
Can anyone tell me where the ping capacitor for the mark III ssb, or tell me why I have a real short chirp or a almost dead bird sound ??
What do I look for ?? :whistle:
cap
Hi the cap ypu need to replace is in the reciver remove bottom cover it should be in the right front corner stock cap for this is a 40mfd 250 volt elrolitic you can put a larger cap like a 60 mfd for a longer squeel but it is hard on things. Ben
You think a big part is because I'm using the stock banana mic ??
I guess they pinged fine back then, right ??
Will a amplified d104 work ok with these things.
I know a lot of people use un amplified d104's.
I'm far from green about mics and radios, just never ran an Eagle.
I'm referring to a Mark III specifically......
This Radio is perfect,,, was in the plastic and foam in the boxes
Never had the covers off, and from the original owner.
I would like to think there is nothing wrong with it,
but I can understand what time does to parts.
CAPS
capacitors dry out with age.the radio is at lest 35 years old. Mine was built in 1975 and i had to replce it 10 yeas ago. do some resurch on eletrolictics caps. look on this forum, I think nomad did a whole deal on recapping these old Birds. Ben
