Free 146 GTL!!!
TonyV225 said:
Modulation VR5 or CUT TR29.... Power VR10, (ssb)VR6 (Clarifier modification: Cobra 146 & AR-144) (1) Lift anode of D-30 and connect a 5.6 uH choke in series.
(2) Cut D-32.
(3) Cut both traces on the PCB going to the clarifier .
(4) Solder one wire to PCB ground.
5) Solder a wire from the other cut trace to an 8 VDC source
(note: 8 volts can be found on the cathode of D-50)
(6)This should give you 5 kc of slide.If more slide is wanted then change D-30 to a super slide doide.
Not sure if you read my post correctly but i am looking for a swing mod not a slider mod.
TR29 doesn't do much in regards to swing, all it does is increase your modulation.
