FT 2500 Deaf
  • Thread starter Thread starter main
  • Start date Start date
M
main
Guest
My FT 2500 went deaf. The radio transmits fine and all other functions work, it just won't receive. What happened and how do I fix it.
Main
</p>
Do you have the squelch set correctly and does it make noise when you open it? Have you checked it by keying another radio in the same area as the radio? Check that first. If it isn't the squelch, check the speaker with a meter to see if it is connected to the wires correctly If that seems to be okay then the radio should be serviced by a tech unless you have test equipment and the knowledge and skills to do it yourself.
</p>
