A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
if it smoked when you first turned on the power...or got very hot.....look for a dead short. The only thing that will make that transistor get hot when the radio is not keyed is if current is going through it.
make sure the tab is insuled...make sure the insulator is on the screw that holds the tab to heatsink.
if the final is heating up the problem has to be in that area.
You should always monitor the current draw of th radio when your doing work on it. After replacing any parts and powering up...you should watch the current draw... if you see the radio drawing lots of current...you have a bad short and you should power down immediatly.
The average radio will draw under .5 amps in rx mode.....if the radio draws more there is something getting hot.
Check that mounting tab on the transistor and make sure its insulated.
There has t be a short to ground if its heating up without keying the radio.
