Glass to Russian steel conversion?
  • Thread starter Thread starter MN102USA
  • Start date Start date
M
MN102USA
Guest
Gotta old Henry 2KD2 with weak tubes was thinkin on a retro-fit to a cheaper Russian ceramic triode.Has anyone here done this?Will the input and output tank circuits be able to be reused?I think the plate voltage will work at 2.5KV,have to research the fil volts and amps some more tho,Thanks for any help/ideas...MN102USA
</p>
