Glen Martin antenna lift made for 45G and goes up to 90ft
videorov
Aug 24, 2008
76
71
This Glen Martin antenna track system is diffrent
then the hazer. It has two tracks that fasten onto
the outside of the 45G tower face. This allows
you to have guy wires hooked up on 90ft of tower.
When you crank the antenna up the tower you can drop a set of the guys and then when you are pass
them hook them back up and keep going up the tower. I have the manual and all hardware which
is mostly stainless for attaching the aluminum
track.Nice system if you want to go higher then
50ft the regular Hazer goes. Have manual for too.
No other company makes a design like this.
This is the top of the line in antenna lift systems. Was $2900 reduced it down to $2000
