going tuber help
Mcds26
Apr 1, 2006
27
Cali
I want to get a tube amp i have a davemade base pill amp right now and i wounld like to try a tube amp ... I have been reading but i wanted to know what you guys thought i know i'm going to get this is better then that but I just wanted to ask ... I want to know how much power safely i can run a 110 line and the line is split up it is not one stright line to the breaker .....so a builder and how much power can i run ? thank you guys for any input
Okay, "this" (living) is better than "that" (getting electrocuted).
Remember that tubes are high voltage (HV) devices, and that the HV will kill you if you don't know what you're doing. Learn about HV and about amplifiers before you run out and buy one. Study the circuitry and especially the power supply. Learn how they work, and how to avoid becoming a statistic.
