Grounding Amp ???
jwhawg
Oct 2, 2009
25
Well I guess I'll ask.....
Can someone tell me if my amplifier should be grounded to the grounding bar behind my radios as the rest of my eqpt. is ?
Sounds like a dumb question, but I really can find no other posts that address this question.
Thanks in advance!
Joe
Yes. If for some odd reason it should cause a problem, then un-ground it. I really doubt if that'll happen.
Guess I will give er a try. It seems none of these have a lug to just ground the case? Maybe I "install" one !!
Anyway Thanks for the quick return.
Eqpt. here is Yeasu FT900at, Monitor tuner, Triplite 60a power suply, Modofied d-104 for the 900. Old Elkin (I think) 4 807's for 10m. Higain th6 6el tribander @40ft. Uniden Madison and Nitro300, Avanti Sigma 4, 4 el monoband yagi on 27m 771 The Rocky Mtn Monitoring Station
