grounds
hey ya all,well i"m just about ready to FINALLY install my equip.first questions on so many that might pop up sooner or later is when i ground the 4 batts.in back then the amp and motor maul does each ground to the frame have to be seperate?
what i"m saying is like for the maul,can i run the 4 grounds down to one nut and bolt on the frame or would it be best for all to have there own nut and bolt? if so i"ll have a ton of drilling for everything that has to be ground, :roll:
