guying cable
spongbob
Dec 2, 2010
Hi, spongbob here with another issue. I have a Rohn 25G tower 50 ft that i'm going to guy at the top,but my question is if I use coated cable do I still need to use insulators?
I would use phillystran. If you use coated cable I'd still use insulators. The coating on the cable might hold in moisture and cause an early failure.
Reactions: 222DBFL
