home made quad band vertical band in the air
mr_fx
Oct 8, 2011
1,536
172
173
Kansas City
ok its in the air ( http://www.worldwidedx.com/amateur-radio-antennas/155941-a99-becomes-quad-bander.html
20m is a little long, resonant at 13.2Mhz...
15m is also long, I think around 20.5Mhz
10m is long at around 27Mhz
6m is fine at around 50Mhz, might shorten it a little more
for radials I did 1/4 wave + 5% (or thereabouts), 2 on 20m, 2 on 15m, 2 on 10m and 4 on 6m, I think that the 20m radials should work on 6m as well as they are around 3/4 wave @ 6m, they were made out of old RG6 quad shielded coax I got an end of a roll from my friend
its feed point is at around 25-30 feet
Used the tuner and on 20m (it's around 3.5:1) and worked Nova Scotia today.
Also I can hear a baby monitor at or around 48.85Mhz
I tried to work a local repeater on 6m, best I could get was an s7 on the meter with a bit of pop corn... sad thing is I can do that on my mobile, and its 25 feet lower on the ground
this pick is taken from on top on my roof
well it tuned up great, nice lower reactance and a good match on all bands (20/15/10/6), well at least in the sections of the bands I intend to use.
