How do I add talkback to a cobra 29?
place a 2200 ohm (red, red, red) resistor across the middle pin of the pa jack and the middle pin of the external speaker jack. you can do it on the rear of the board. that gives you quiet talkback.
Solder side, I find a 1watt 100ohm works well, loud enough to hear, not to loud. If you wanted to do variable talk back use a 500 ohm pot, 1/2 or 1 watt. Anything smaller will burn out.
