Icom 7000 Starts in TX mode
gberges
Oct 4, 2009
3
Regardless of which band or mode chosen in the band selected, with antenna and/or microphone and/or earphones connected or not, powered by 12v battery, when I turn on my 7000, the red TX light is always on. When last I turned it off, it was working well. All I did was move it to a different location. Any ideas, troubleshooting tips or suggestions would be very much appreciated. Thank you. Gus, NU4L.
Maybe a factory reset may take care of the issue if nothing else works. you should be able to look the procedure up in your manual.
Is it hooked up to a PC by chance? Did you check to see if the Tune button is stuck in?
Icom company needs a spanking Im thinking. I hope its something simple and not serious like alot of the other rigs Ive read about. :w00t:
