Jo Gunn Smokin Gun ll
Would you have the element measurements
Barry I don't have the dimensions, but here is the Manual attached in the PDF file below.
Notice that the JG antennas come pre-marked and that makes assembly simple (their words).
If you have the antenna and it was previously installed, then check real close and see if you can still see some setup marks left on the tubing.
  • Smokin' Gunn II.pdf
