A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
I need instruction on how to get lowers, specifically 26.905 out of the m58472p pll. Hopefully by just controlling pins. This is for an AM mobile. Your wisdom is appreciated!
The PLL is not expandable, I have not seen a radio that uses this PLL, but the info I have available says that the radios that use this PLL can be expanded by changing the loop mixing crystal, sorry I cant tell you any more than that.
Wow spike posted this on Dec 31, 1969 he must have been part of arpanet!
(I know this forum must have gone through upgrades & hosting server changes)
I just made a purchase on a channel master unit that uses this same PLL, if you go here secret_cb_vol_16_pg33 one can find some info on expanding it to 26.935 also some of the "regular 40 channels" can be obtained with a switch.
(I posted this just in case someone else comes to this forum to search for "M58472P", this thread was all I found here.)
