Magnum Delta Force losing power on SSB
Ham Radio Nerd
Apr 14, 2002
9,375
2,122
383
Lately, my RR tuned Delta Force seems to be losing output power, but only on SSB. What's wierd is that on AM, I see a good 20 watts and on FM about 25, which seems perfectly fine. Originally on SSB, I was seeing a good 30 watts, but all the sudden, it dropped to about 15 watts. I flicked the ALC which bumped it to 19, but that still doesn't seem right. Any suggestions? (other than send it in...<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/nerd.gif ALT="8o"> )
</p>
HMMMMM! That dont sound to great! I hope you find out what is causing this little problem!
</p>
You might try to replace the ALC trimmer if it's having an effect when plucked. I can't recall if that was a used unit or a new, if it was new it should still be under warranty. I want to say it was a trade we worked and a trade in to me. Nevertheless a funky pot will do that, investigate that first.
Wm. Warlock "71 and the long limousine in Va"
Rollingradios@aol.com
Nat. Rep for XForce/Magna Force Customer Service and Support
</p>
Yeah, this was a trade, so no warranty. That sounds like a good idea on the ALC...I'll give that a try tonite and see what happens.
Thanks!
</p>
