MCP-4a Software: How to import without losing other config data?
rcollette
Apr 27, 2011
7
I am using the MCP-4a software with my TH-D72A.
I load an existing configuration into the software
I then import a tde formatted repeater list from K5EHX.com.
They load in which is awesome and saves me a ton of time.
However, I am losing my other configuration information that was already in the file. It would be much better if it would do an insert at the currently selected memory number.
Does anyone know how to do an import without blowing away other configuration information?
Thank you.
Download from the radio and save as a .hmk file, and save your K5EHX as a .hmk file and use excel to copy/paste the two files together. You could even use notepad but you have to manually change the memory number.
I just tried it using notepad and it worked, excel should work but might be a few more steps
