Here are some nice up close pics of the Merlin Base Antenna.
These pics will let you see what $256.00 shipped to my door looks like and the type of craftsmanship that went into this antenna.
I have not tested the antenna as of yet.
Directions/Assembly provided with antenna.
Top Hat Section
Top shaft base adjustment.
Base Section.
SO239 Bracket.
Base of antenna. Lock pin after grinding.
Lock pin for radial. No grinding.
Mounting holes. Note alignment.
View of base from above looking down.
Radial 1.
Radial 2.
Radial 3.
Radial attached to base. Note holes do not line up.
One radial attached for perspective.
Top Hat Section
Base Section.
SO239 Bracket.
Radial 1.
Radial 2.
Radial 3.
