Meters
  • Thread starter Thread starter Peddler 356
  • Start date Start date
P
Peddler 356
Guest
Here is an opportunity to express your ideas on a not so well know meter in the CB world besides a BIRD 43.
The meter in question is:
PALSTAR WM150 palstar.com/wm150.htm
Any constructive comments are welcome.
The Peddler...
Website
</p>
Hello Jim,
I have one of these, The Palstar WM150 base model, I like cross needle meters because I can watch both forward and reflected power at the same time as I tune My antenna tuner. I feel it is better because you can see what is happing with both...your swr is not going down because your output is going down, because of a bad match kind of thing. I feel it gives you a better picture of things in that case.
Power readings are easy and it reacts fast on the "Peak" mode. If I had it to do over again, I would get the one with the remote cable, so It is easier to set up with the stiff jumpers I am using(it is 1318-FX, but it still is not THAT flexible)and sit well on top of the tuner.
Another thing, you can get a better price than is listed on the Palstar website, there is a guy selling them cheaper(with factory warranty) on E-Bay.
There are some reviews on E-Ham I think...or QRZ if you want to have a look, but all in all I like it.
CDX 339
RadioActive
</p>
One more thing I forgot to mention, you have to have 12 volt to use it, the Active peak reading circuit requires that you have 12V for it to read forward power...they include a wallwart to power it in the house, and there was a DC plug end in the box for you to wire your own DC cable for mobile use, but the wire/cigarette lighter plug is not included.
CDX 339
RadioActive
</p>
