Mic Wiring for Uniden Grant!!!
15minigrass
915
29
53
Just got a 5 pin side mic 4 button Uniden Grant Grey face similar to a President Grant DX.
I need the mici wiring pin out.... I tried a 148GTL 5 pin mic but it didnʻt work.
are you sure this radio works?
if it has the same 5 pin connector as the 148GTL type connector, then they are the same radio on the inside and your mic should work just fine.
you might try jumpering a few pins together on the grant to see if you can get it to key up or receive.
