Mil Freqs
Operation Iraqi Freedom Shortwave Frequency List
Thanks for the link MudDog.
I will go ahead and post the freq's from that link in case that site goes down for some reason or another.
Here they are.
Nighttime Frequencies
3.178 MHz USB NATO Bookshelf Network
3.900 MHz USB NATE E-3 AWACS Network
3.930 MHz USB
4.519 MHz USB USAF EC-130's & Bookshelf Network
4.542 MHz USB
4.720 MHz USB
4.724 MHz USB UID station calling Architect (Royal Air Force) with code word "Miller Time"
4.758 MHz USB
4.832 MHz USB DFZG Ministry of Foreign Affairs Belgrade
5.142 MHz USB RC2SAR Int. Committee of the Red Cross Sarajevo, Bosnia & Herzegovina to RC2TRE Int. Red Cross Trebinje, Bosnia & Herzegovina
5.218 MHz USB NATO Bookshelf Network
5.245 MHz USB Republic of Ireland (nightly) repeats same message: "This is a coded drill message bravo bravo charlie, charlie hotel 4, charlie november november
5.325 MHz USB
5.598 MHz USB HAVOC11 In refueling Block 250/260 enroute you know where... Next reporting point Madrid ATC on VHF. 3 B52's in formation
5.691 MHz USB
5.717 MHz USB Canadian Forces
5.7635 MHz USB NATO Bookshelf Network
6.628 MHz USB Operation Allied Force
6.651 MHz USB Danish Air Force, RCC Karup. Primary Day Freq
6.693 MHz USB US Navy - Adriatic Task Force
6.697 MHz USB Navel High Command
6.712 MHz USB French AirForce Between France & Italy. Main Call is "CIRCUS VERT", planes using COTAM xxxx callsigns
6.723 MHz USB NATO Freq. All day in the air
6.728 MHz USB NATO AWACS activity Callsign MAGIC being used, usually means E-3 AWACS planes
6.739 MHz USB U.S. AirForce GHFS
6.761 MHz USB AirForce ReFueling Freq
6.865 MHz USB EC-130's stationed at Aviano, flying with the callsign "Moonbeam"
6.912 MHz USB
6.9325 MHz USB NATO Bookshelf Network
6.959 MHz USB
6.993 MHz USB
6.996 MHz USB
8.046 MHz USB NATO Bookshelf Network
8.087 MHz USB NATO Bookshelf Network
8.825 MHz USB Operation Allied Force
8.921 MHz USB
8.980 MHz USB AWACS MAGIC callsigns being heard here, mostly week sigs in Pennsylvania
8.982 MHz USB US Navy - Adriatic Task Force
8.989 MHz USB
8.992 MHz USB US AirForce GHFS
9.007 MHz USB Canadian Forces
9.016 MHz USB US AirForce
9.023 MHz USB US AirForce
9.1185 MHz USB NATO - Bookshelf Network
9.260 MHz USB NATO - Bookshelf Network
Daytime Frequencies
10.175 MHz USB
10.204 MHz USB US AirForce GHFS
10.315 MHz USB NATO - Naval Command Network
10.780 MHz USB
10.915 MHz USB Task Force Hawk - Code Name JAGO
11.140 MHz USB Operation Allied Force
11.173 MHz USB
11.175 MHz USB US AirForce GHFS
11.226 MHz USB Tanker Operations "Bolero" at Moron Air Force Base (Spain)
11.239 MHz USB BRAVO BRAVO talking to DUMBO DUMBO seems to be either a bomber or tanker
11.243 MHz USB Gibralta FlightWatch giving aviation weather for Italian Military Bases. (Italy is less then 100 miles from Kosovo)
11.244 MHz USB Long EAM's heard here as well as on 8.992
11.990 MHz USB Kuwait emergency broadcasts.
11.300 MHz USB See Note Below
13.200 MHz USB US AirForce GHFS
13.204 MHz USB
13.243 MHz USB
13.257 MHz USB Canadian Forces
13.354 MHz USB Operation Allied Force
13.458 MHz USB Raven Operations (Tanker Aircraft)
14.906 MHz USB Serbian Embassy Moscow, Russian Federation to DFZG Ministry of Foreign Affairs Belgrade, Serbia.
15.016 MHz USB US AirForce GHFS
15.031 MHz USB Canadian Forces
15.048 MHz USB NATO - Bookshelf Network
16.442 MHz USB Naval Hotel Tracking Network
With the U.S. commencement of attacks on the Taliban etc. the USAF Global HF frequencies are active. 11.175.0, 11.125.0, 11.225.0 mhz has been non stop with two way transmissions.
Afghanistan Frequency List
Kabul International Airport
HF; 10018, 5658, 3467, 6547, in use
HF; 4132, 2966, 6828.5, 7318, available but not in use
VHF; 128.500, 118.100, 121.900, 125.000 MHz
Kandahar Airport
VHF; 118.100, 128.500 MHz
Herat Airport
VHF; 118.100, 128.500, 121.900 MHz
Mazar-I-Sharif Airport
Jalalabad Airport
VHF; 118.500 MHz
Continental US Based Air Force
127.2750 - DCANG 113th FW out of Andrews (sporadic because part-time CAPS)
139.9000 - DCANG 113th FW "Supervisor of Flight" frequency (same applies)
138.4250 - Air National Guard out of New Jersey (can hear in DC area often)
277.6000 - NORAD
254.2000 - AWACS
252.1000 - 119th Fighter Squadron out of Langley AFB (interplane chatting) F16s
Military Callsigns
NLC**** Navy P3C's
ARRAY Possible HF relay stations for logistical opts from Dover AFB
BELLY B2 Bombers, I've heard reports that Belly could also be B52's
REACH USAF Mobility Command, C5's, C17's, C141's mostly GOLD B52 Bombers
MAZE Unknown at this time!
MAGIC AWACS planes
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=charger383>Charger383</A> at: 4/3/03 7:12:59 am
