Need help: looking for simple rise and lay antenna mount
L_B
Sep 29, 2010
3
Hi, I am searching for an antenna mount that can either be side mounted or roof mounted that allows a mounted antenna to be raised and lowered. I stumbled across this forum and believe i hit the jackpot. Can anyone help me?
The antenna is approx 2 feel in length and 2-3 pounds in weight. The mount should be motor operated, similar to this one: Lift & Lay
Thank you in advance for any help!
You also have the option of designing/building your own motorized mount. Depending on how/where you do that mounting, designing your own might be easier than buying one. Lot's of "but's" with that, so you decide about that.
Not sure if this guy is still building these or not...But it sounds like something you maybe interested in...May try giving him a call. He lives near me, but I haven't talked to him in a while.
