Need Help with 26 x mrf150 Board
fm969
Feb 16, 2010
10
I'm looking for someone who can help me with a project I have.
I have an amp board that I got from a guy in Florida, It has 2 driving 24 mrf150's. It is complete and mounted on a heat sink.
Not sure where it came from, but it is industrial looking and high grade made.
The only name I can get from the board says Teli ???
There are 3 separate boards on the 12 x 18 inch heat sink.
1 board with 2 of the 150's that says driver.
and 2 boards that say 2.5 kw. on each, with 12 x 150's on each.
There is also a matching system between the 2 boards that is covered with a copper cover.
So that's at least,,, 5 kW.
and you can put under your arm.
Now I do know that the mrf150's are 48 volt and they are very wide band and will go up to 150 mhz.
First, I want to ask if the mrf150's will work efficiently on 27 mhz. ???
Tell me what you think and lets kick this around a little.. :lol:
Oh yeah,,, I also have 3 continuous duty 48 volt power supplies too.....:biggrin:
