New Alinco DJ-V57T 2m/440 HT is approved by the FCC and available
Ham Radio Nerd
Apr 14, 2002
9,317
1,998
283
The new alinco DJ-V57T 2m/440 5 watt HT has been approved by the FCC. Universal Radio is showing them available for $139.95
This ruggedized HT has the following features:
  • 3 power output levels: High 5W(13.8VDC), Low 0.5W and user-selectable Mid-power (1-3W)
  • Quick-write memory channel (Uses a single key touch to copy current VFO data to the Lowest number of memory channels available)
  • Direct frequency input through illuminated keypad
  • High-grade water-resistant materials compatible to IPX7
  • Rugged polycarbonate body resists dirt and dust
  • Large 40mm internal speaker
  • Backlit alphanumeric display
  • 200 Memories, plus one call channel on each band
  • VFO, Memory and Scan modes
  • 39 CTCSS tone squelch (encode + decode) and 104 DCS
  • Search-scan (programmed scanning) available on each band
  • Tone burst function (1000, 1450, 1750 and 2100Hz)
  • Battery-drain function avoids memory effect
  • Two-touch repeater-setting access
  • Internal VOX
  • Wire cloning capability
  • SMA antenna port
  • 2-level attenuator
  • DTMF encode and auto-dialer
Hopefully we'll see some reviews of these soon!
