NorthPoint NT-6-HP
hollywoood
Dec 4, 2011
11
Could any please tell me, believe it is J103 on the main board, there is connector has approximately 12 wires coming out of it, (on this one a few are cut). I need to know,.. where the blue wire, the one I am talking about appears to come out of 'slot #37' it is the second wire in from the left as you look at radio from front speaker cover side between the yellow and red wire)?
If you could be somewhat detailed in your explanation of where the other end gets soldered I sure would appreciate it,.. I am totally ignorant but on the same hand do not have a lot of knowledge with these radios.
I will get back to you with any further information you may need asap.
Thank you!!!!!
