Opek SWR-3 meter?
Turbo T
Certified CB Rambo
Feb 2, 2011
963
142
53
Anyone ever used one? What's your 2 cents on it? OPEK SWR METER
Saw one of these at a hamfest today. The seller said it works on 2 meters and 11 meters. Also said it has the capability of detecting signal strength with a little antenna on the side. All for $20.
Take a look at: EHAM - Opek SWR-6 Average rating: 4.2/5
Might be good for checking antenna patterns at power of 100 watts or less.
Oh I guess it does swr checks too.
The SWR-5 would meet 11 meter needs better unless you need a field strength meter.
I only purchased this because the ham selling it advised it would work on 2 meters and 10/11 meters. I was buying antennas and such for when i get a 2 meter radio.
From the Opek website
Welcome to OPEK.
Frequency of what you asked
26-27 MHz=11 meter
28-29.7 MHz= 10 meter
144-148 MHz=2 meter
FREQUENCY: 1.7-150 MHz
IMPEDANCE: 50 OHMS
ACCURACY: +/- 5% (SWR), +/- 10% (POWER)
POWER RANGE: 0-10 W/ 0-100 W
DIMENSION: 145(W) X 52(H) X 57(D) mm
So according to the specs, Yes it will cover all three bands you asked about, AND MORE!
