Parasitic Suppressors
jp1116
Apr 3, 2005
11
Can anybody tell me what size wire to use to make some parasitic suppressors for a D&A Phantom? Does it have to be tinned or will copper work. Also, using the resistors available today, when do you put the resistor inside the coil and when should you put it outside. I remember reading something about putting it outside if there is ceramic in the resistor but can't remember for sure what it was.
</p>
