I will refresh your memory of my op. In ssb mobe every amp I use was ocastionaly keying the amp in ssb before I modulated.
With the Madison's mic gain turned off the amp would not key. This was happening with both my main mic's (silver eagles).
I gave both the connecting bars that allow the side keyer to depress and activate the mic's really to key the rig. While this premature keying of the amp only happened aproximrtly one out of ten times. I thought it might be spurious imisstions causing this problem.
I never use the lazy key ever to key the mic. after giving both the side key bar a shot of deoxit the problem happened even less then it ever has. I only ever used the side bar to key the mic. I decided to try keying the mic with the lazy bar (mic gain on rig and mic at my usual settings). Well the lazy bar keyed the amp every time I pushed down on it.
I switched to the other silver eagle and the same thing happened.
The lazy bar on both mic's key the amp in ssb mode with no modulation every time I push down on it.
The lazy bars must be causing an audible klicking sould (as I myself csn hear a slight metal on metal klick) causing the amp to key .even after I gave the second mic's lazy and Side bar a deoxit shot, the lazy bar still constantly prematurleyed key the anp without modulation every time.
Theses lazy bars are activated even while using the side bar. This has to be the problem. I'm not familiar with the way keying bars work in concert but I'm sure if I remove the lazy (base keying bar) leaving only the "chicken chocker" keyer as the only way to key the mic
the premature ssb of the amps keying circuit without modulating will cease. Im unfamiliar with the way theses bars work together. Can the base (lazy bar) be removed without affecting the side bars operation?
I'm convivinced this is the problem and not stray rf. Thanks
