President 2510 ERR 4
Thestonerguy
Guest
Apr 3, 2005
338
2
26
Texas
www.cbgazette.com
This may be an easy one, but on transmit when you key on AM it immediately goes to an ERR 4. On SSB it takes strong audio to get that same error. Don't have a manual, I'm guessing SWR?? But the rig before that didn't have any issues (not to say something couldn't have changed). I'll get around to checking the swr in the next day or so, but thought that someone may have run into this before - Tnx!
From The ChipSwitch Manual:
Quote:
Err X"
where X is:
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit (programmed)
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
What Frequency were you TX`ing on?
Got stray RF in the shack?
Solid voltage supply?
I had this error code show up when I installed a powerline filter. Once I took the filter out of line the rig worked fine. It didn't matter where the filter was installed, either at the battery or close to the rig it still had the code show up. Interestingly enough, it didn't do it on AM but only on SSB when modulation was applied.
