Pyramid Power Supp Volts
  • Thread starter Thread starter Mr Gnome1
  • Start date Start date
M
Mr Gnome1
Guest
On my Pyramid PS-52KX power supply it drops from 13.80 volts to 13.65 with just my Cobra XL 350 amp hooked to it doing around 300 watts.This is checking at the same terms that the amp is hooked to. If I check at the extra set of terms where nothing is hooked to there is only a drop to 13.79.
I also checked my Pyramid PS-26KX with just the radio doing around 25 watts and it will drop from 13.80 to 13.79.
Is this normal?
Anything to worry about?
Will running the volts a little higher hurt?
On the PS-52 if I tap the two sets of terms together will it help, hurt, have any effect, etc?
Thanks,
Mr Gnome
</p>
Not sure but I think you're supposed to tap off of both sets when exceeding 25a draw. Cranking the volts should be fine, stay below 16.
Wm. Warlock "671 in Va"
Rollingradios@aol.com
Nat. Rep for XForce/Magna Force Customer Service and Support
</p>
Thats what I always did with mine R&R.
CDX-22
YG22
2TA01
2TX922
AE922
2SF22
WV22
US Army
</p>
