Radio drops a couple watts with amp inline..
CB590
W9WDX Member
Jun 29, 2016
1,545
1,265
173
Trenton Nj
www.590dx.com
So my Ranger 296 swings say 6-8 with voice modulation on my meter normally (whistle to 14w). But when I put my RM203 inline with it and power line powered (as required to work) my audio only gives me like 2-3w with same audio modulation.. I also get 2-4w or so with amp on (SSB mode)
Meter is between radio and amp.
SWR is flat as checked without amp inline and direct to A99. (Correction/edit 1:1-1 near 40 and 1:1-1.2 on channel 1)
Could there be a limiter in the amp dragging it back to lower??
I can whistle the watts to about 10w on SSB mode.. just seems tighter to get it there..
Got good audio reports with skip and barefoot without amp inline and the 6-8w audio.. just figured a kicker for the pileups..
Between radio and amp is where the meter is located. It's showing flat...
I guess, that is with the amp off.
just turn the amp on,... if the SWR changes much ,... then see post #2.
.... or you can use one of special length jumpers between the radio and the amp:D
I moved the meter to after the amp.
With a 1w dk I get a 25w dk, on SSB with say 12w whistle I get 120w and SWR not above 1.2:1
With my TS350 in play I get a 50w dk using a 1w dk, and in SSB and 12w whistle I get 220-240w from that and SWR of a little less than 1:3:1..
So I guess all my worrying was for naught..
Reactions: S&W357
