RCI 2950DX
zinger827
Supporting Member
I Support WorldwideDX.com!
Mar 9, 2008
456
41
38
Maine
I have a RCI 2950DX problem is only has 1-4 watts power on AM? FM has 2-8 watts SSB has 20 watts. Any ideas AM regulator or what? Thanks.
You might have to start from step one and go through the whole alignment procedure from cb tricks. If you know how to do that you are way ahead of any advice I could give you. Hope you figure it out though.
Zinger,
Sounds like the same problem I had, I adjusted the PLL and I got back my 30 watts. PLL gives alot of problems when not aligned properly.
