RCI 69 Base Plus-no average swing
Metalhead
Jan 15, 2020
22
3
13
64
I just unboxed my new radio and did the 11 meters conversion. I'm using a Bird 43 meter with a Peak kit in it. The average watts are at 30 when you key the mic with no swing. If you turn the power down the wattage goes down but still no swing. My PEP is 110 watts. Why is there no forward swing on average?
Because it is a stock radio. A properly set up NPC-Rc mod will give you the swing you are looking for. Should be similar to the 2950 surface mount board.
Reactions: BC Coyote
