When tuning one of those 8" 8 turn rf chokes below the feed point is there an length of coax to leave between the 239 and the choke itself that will work best?
The CB tuned choke is either a 4 or 8 inch coil form with five winds of coax.
I certainly wouldn't form RG213 into a 4.25" diameter coil. RG-58, or RG-8x, no problem.
Rule of thumb: Bend Radius should be at least 10X the outer diameter of the coax. RG213 has an OD of 0.405" -- call it an even 0.4". Ten times that is 4 inches.
Now, since we're talking Bend RADIUS, the coil has to have a diameter of EIGHT inches. Diameter equals twice the radius.
I've the non flex 400 and thought using four or five toung depresses cut to size and placed in iintervals and taped on the inside of the coiled coax then held in place with the wire ties would do the job and save on weight.OK. Then use five winds of the LMR 400 on an 8" diameter plastic form. Make sure the winds are close together and kept in place with some tie wraps and you should be good to go. There are lots of examples online on how to do it and what materials to use.
Its 5 turns of RG58 or RG213 on a 4.25" core. The amount between it and the antenna socket isn't critical but closer is better
The CB tuned choke is either a 4 or 8 inch coil form with five winds of coax. Yes; it makes a difference. Keep in mind, that the number of turns changes the tuning of a choke's usable freq.
What if I'm using RG6 coax?
Also I read somewhere that it was the length of the choke and not the number of turns. Trying to figure this out is getting more complicated. Still, I think it will be worth my time to actually build an antenna than too simply buy one. Hopefully it will get easier along the way.
